查看: 2968|回复: 6
请问E-sys设定已设定完成,开启有以下错误该怎么做?
25
422
447
论坛捐献
发表于 2023-1-3 12:02:16 | 显示全部楼层 |阅读模式
E:\psdzdata\psdzdata\mapping\brref.xml file is missing in psdzdata directory. [2107]
_____________________________________________________
com.bmw.esys.domain.psdz.PsdzException: The content of the current psdzdata folder "E:\psdzdata" is invalid or empty.
Please import a valid PDX-Container. [G270]
        at com.bmw.esys.gui.control.Framework.main(Framework.java:214)
Caused by: com.bmw.esys.domain.psdz.PsdzException: Set PSdZ-Root using "E:\psdzdata" failed! [C073]
        at com.bmw.esys.domain.psdz.PsdzConfiguration.setPsdzRoot(PsdzConfiguration.java:55)
        at com.bmw.esys.domain.psdz.Psdz.setPsdzRoot(Psdz.java:494)
        at com.bmw.esys.gui.control.Framework.main(Framework.java:211)
Caused by: Initialization of PSdZ failed due to following reason: E:\psdzdata\psdzdata\mapping\brref.xml file is missing in psdzdata directory.. All previously applied changes during the initialization process will be undone.
Timestamp: Tue Jan 03 11:57:03 CST 2023
Class: com.bmw.psdz.configuration.facade.ConfigurationImpl
ExecutionContext={category=UNDEFINED, ecuid=(UNKNOWN,?)}
        at com.bmw.psdz.configuration.facade.ConfigurationImpl.setRootDirectory(ConfigurationImpl.java:1287)
        at com.bmw.psdz.facade.ConfigurationBF.setRootDirectory_aroundBody2(ConfigurationBF.java:74)
        at com.bmw.psdz.facade.ConfigurationBF.setRootDirectory_aroundBody3$advice(ConfigurationBF.java:84)
        at com.bmw.psdz.facade.ConfigurationBF.setRootDirectory(ConfigurationBF.java:1)
        at com.bmw.esys.domain.psdz.PsdzConfiguration.setPsdzRoot(PsdzConfiguration.java:49)
        ... 2 more
Caused by: E:\psdzdata\psdzdata\mapping\brref.xml file is missing in psdzdata directory.
Class: com.bmw.psdz.pdx.repository.seriesmapping.SeriesMappingFactory
        at com.bmw.psdz.pdx.repository.seriesmapping.SeriesMappingFactory.create(SeriesMappingFactory.java:49)
        at com.bmw.psdz.configuration.facade.ConfigurationImpl.doFA2FPMapping(ConfigurationImpl.java:499)
        at com.bmw.psdz.configuration.facade.ConfigurationImpl.initMappingFilesAndSecLib(ConfigurationImpl.java:945)
        at com.bmw.psdz.configuration.facade.ConfigurationImpl.setRootDirectory(ConfigurationImpl.java:1236)
        ... 6 more
31
23
54
发表于 2023-1-4 13:45:48 | 显示全部楼层
你的数据库设置有问题,看你设置是E:\psdzdata,你如果将psdzdata直接放在E:\,那么数据库设置你也应该设成E:\  让E-SYS 自己在E:\寻找psdzdata,你如果设置成E:\psdzdata, E-SYS就找不到数据库了
评分
参与人数 1金钱 +10 收起 理由
bmwche + 10 用心讨论,共获提升!
查看全部评分
8
16
24
发表于 2023-1-6 14:33:47 | 显示全部楼层
高手好多啊!
78
79
157
发表于 2023-1-9 17:19:20 | 显示全部楼层
你的问题搞好了吗?
141
73
214
发表于 2023-1-11 09:40:01 | 显示全部楼层
都是高手,看不懂。
19
44
63
发表于 2023-1-11 22:33:02 | 显示全部楼层
觉得还可以吧
25
422
447
论坛捐献
 楼主| 发表于 2024-9-23 01:33:43 | 显示全部楼层
nengzhewujiang 发表于 2023-1-9 17:19
你的问题搞好了吗?
已搞定,謝謝
GMT+8, 2026-5-2 20:01 , Processed in 0.050542 second(s), 31 queries .
