楼主 |
发表于 2026-8-29 22:33:31
来自手机
显示全部楼层
NBT+TCB的完整教程,没试过,自行翻译吧:Forum Tools Required: - Tool32, which is part of EDIABAS; - HxD, or any other hex editor you feel confortable with; - Tools compiled by me to parse the data extracted from Tool32; - Notepad+, or any other text editor you like in order to make changes to the xml file. Procedure: - Start E-Sys, read the CAFD of your NBT unit and with the FDL Editor look for the entry DPAS_INDEX. This will tell you the DPAS value you will have to use with Tool32; - Start Tool32 and open the NBT.prg (You might need other prg like ENTRYNAV.prg. Find the one the let's you communicate with your ECU.); - Run the job: apiJob("NBT","lesen_provisioning_data","3;2;0",""). In this case, "2" is the value reported by the entry DPAS_INDEX; - Run the Application " Windows or Mac " version to parss the file on the correct format - Open the saved file ; - Select the data inside the file and copy it in a hexadecimal editor; - Save as XML file - Now you have your complete xml file generated; - Save the new file and note the location. For example: C:\file.xml; - Edit your file with Notepad+ to activate whatever you like (Examples below); - Save the changes (Notepad+ will warn you if there are errors with the xml); - Upload the file to your car, using Tool32, with the command: apiJob("NBT","steuern_provisioning_data","3;c:\file.xml;2",""). In this case, "c:\file.xml" should be your file and "2" is the value reported by the entry DPAS_INDEX; |
